Some quick looking around resulted in this. Notice the connecting rod information.
Type: 1.8L I-4 Fam1 Gen3 ( LUW )
Displacement: 1796cc ( 110 ci )
Engine Orientation: L ( longitudinal ) T ( transverse ) T
Compression ratio: 10.5:1
Valve configuration: Dual Overhead Camshafts (DVCVP)
valves per cylinder: 4
Assembly site: Bupyeoung, Korea or Toluca, Mexico
Valve lifters: Direct acting tappet with hydraulic lash adjuster
Firing order: 1 - 3 - 4 - 2
Bore x stroke: 80.50 x 88.2 mm
Bore Center: ( mm ) 86
Bore Area: ( cm2 ) 203.61
Fuel system: Sequential fuel injection
Fuel Type: Regular unleaded
Applications: Horsepower: hp ( kW )
Chevrolet Cruze 138 hp ( 103 kW ) @ 6300 rpm SAE Certified
Chevrolet Sonic 138 hp ( 103 kW ) @ 6300 rpm SAE Certified
Applications: Torque: lb-ft. ( Nm )
Chevrolet Cruze 125 lb.-ft. ( 170 Nm ) @ 3800 rpm SAE Certified
Chevrolet Sonic 125 lb.-ft. ( 170 Nm ) @ 3800 rpm SAE Certified
Maximum Engine Speed: 6500 rpm
Emissions Summary: GM System 0 Engine Management System with E83 ECM
Federal: Tier 2 BIN 4
California: BIN 4 ( ULEV2 Qualified )
MATERIALS
Block: Cast Grey Iron ( hollow frame )
Cylinder head: Cast Aluminum
Intake manifold: Composite
Exhaust manifold: Fabricated Stainless Steel Maniverter 4-1
Crankshaft: Cast Nodular Iron
Camshaft: Cast Chilled Iron
Connecting rods: Forged Steel
Additional features: Double Continuous Variable Cam Phasing ( DCVCP )
Varible Two Step Runner Length Intake Manifold
Electronic Throttle Control
Electronic Controlled Cooling System
Hydraulic Tappets
Cylinder Selective Adaptive Knock Control
Engine Oil Cooler with Individual Piston Cooling Jets
Individual Coil on Plug High Energy Ignition
Extended Life Coolant
3 Layer Sheet Metal Cylinder Head Gasket
Belt Driven Camshaft
Long life (100,000-mile) spark plugs
"Like the pistons, other reciprocating components in the 1.8L were developed for an optimum mix of strength, balance and low weight. The result is less reciprocating mass inside the engine, increasing efficiency and enhancing the tactile feeling of performance as the engine builds revs.
The steel connecting rods incorporate a larger, forged I-beam cross section for added strength, without increasing weight."
All information from GMpowertrain.com
