I've been dealing on and off with a P0011 code for over a year and it won't go away. The Sonic has been in the shop 4 times total at 2 different shops in addition to my own repairs.
I'm at the point the car runs/works perfectly fine, all readiness tests have passed, but the service light is still on (with only a "historic fault" P0011 listed)
I've had a new timing kit installed, a new timing gear, the timing readjusted approx 7 months later, new exhaust side solenoid, new intake side solenoid (twice), 3 oil changes, 1 oil system flush/cleaning, and wiring checked. The faults have been cleared after each, and At best I went 3 months with the service light off, at worst, I made it 8 miles from the shop before it was back on.
I'm already in $2500+ in total trying to fix this and my emissions/registration was due almost 2 months ago (2 failed emissions tests because of this and can't get the exemption yet).
First I've seen the "historic fault" through all this, so not sure if that's a good sign or not. Should it go away on it's own soon after so many cycles, or am I still trapped in P0011 hell?
...help T_T
...help T_T
