Swordsmith
242hp/252 ft-lbs BNR EFI
I had the fog lamp blanks out so I could dremel them out for CAI and a set of effect LEDs, while I had the port side one off I went ahead and swapped in a new horn, very easy access from there.
i just replaced mine with the wolo bad boy today. I just jacked up the front left tire, removed the liner, and did my thing. I didn't even have to remove the washer fluid reservoir.
Definitely sounds better, but I do miss hearing the horn when I lock the doors, or when I use the locator button to play the horn 3 times.
True, though not as loud as I would like. I'm looking for a train horn! :banana:
