im just gonna put an auxiliary switch so i can turn them on and off when i want.
If you wire them to the daytime running lights then the headlights wil be on when the halos are on. I would run them off the parking lights. Then you would only have the side markers on and the halos. Also make sure you get low current halos. If they draw too much you will start blowing fuses.
I could do that but i want the interior as clean as much as I can
That would be redundant as you said, if you left the headlights connected for daytime running.
I imagine it's possible to have the Halos connected to daytime running instead of the headlights.
I was under the assumption that the headlights and the daytime running lights were the same thing. The same light turns on. Its just when the computer tells the headlights to turn on, it kicks on the parking lights and taillights as well. If you were to hook them to the parking lights on the sides, you can turn your headlight switch one turn, causing only the parking lights and the halos to turn on. And in turn causing them to all be on when the headlights kick on at night.
The DRL function is a lower voltage, correct?
So, as I've never dealt specifically with newer DRL setups, it's highly possible that, as you say, an ECM takes care of exactly how the light behaves.
If the same wire is used for DRL and headlight modes, then yea, my suggestion is definitely invalid.
Too bad if that's the case, DRL's suck a$$.
A drain on the life of my bulbs and I can't substitute a low-draw, better looking LED array? crap. :sadbanana:
Maybe one of these would work. They're clean and discrete looking and have a light so you know when they are on. I would use blue or yellow. Probable blue.
