Llia
Can you list:
- Mileage the failure occurred
- What the Failure(s) was/were
- What part of the globe you're located in. Lon/Lat Finder (You don't have to be exact) or at least the Average temperature in your area at the time of the failure or on average.
Seems most parts that fail are due to heat. If that is part of the reason then I'd like to find out if those in cooler climates still experience the same failures at the same mileage.
This Block Will Be Updated
Code:
PCV HOSE
TEMP 70-80
110K (Oil, 3K) (Octane)
INTAKE MANIFOLD ( PCV )
TEMP 90-100
43K
45K
98K
WATER PUMP
TORQUE CONVERTER SEAL
TURBO
TEMP 90-100
43K (Oil) (86 Octane)
63K (Full Syn Oil, 3K) (93 Octane)
VALVE COVER
TEMP 90-100
43K
43K
