So I drive a 2012 sonic 1.8 with auto tranny that literally just hit 100k miles today. Just recently I have been having shifting problems and a few other problems literally after I changed the valve cover for the new pcv valve. So what its doing is 2 things, taking a long time to down shift while driving 70+mph and staying in gear longer than before, and when driving and going to speed up to pass a vehicle, it jerks and doesnt shift when it needs to and makes the car slow until it finally shifts. Now the second one doesnt happen all the time but the first does. Will it need to be replaced or can I change the solenoids inside the transmission? Also, how do I find out what type of tranny the car has so I am able to find the right parts? Ive seen youtube videos on the solenoids inside and how to remove them which looks simple, and the problems im having seem like the cause of a bad solenoid. Quick note, I changed the transmission oil about a month ago.
The transmission for the 2012 sonic with 1.8L is a 6T30 trans. The 1.4L has the 6T40.
As for the the problems you are describing, I have had the same issues since I got the car(about 58,000 miles ago). Car has almost 157,000 miles on it.
When does your car shift late? Does it slam into gear?
Mine, for example, shifts late going into 3rd then really shifts late going into 4th, and when it shifts into 4th it really slams into gear. I’ve noticed that this problem has only gotten worse the longer I’ve had the car. If your problem is like mine then it could possibly be a solenoid but the more likely issue is with the 3/4/5 + Reverse clutch pack is bad. That’s a common problem with the 6T30/6T40 transmissions.
Is your transmission fluid burnt? Have you had someone with a scan tool check the operating temperature of the trans? One day I was doing highway driving and the trans temp got as hot as 220°F, which is way too hot and the fluid starts to degrade after 200°F usually.
