DevilSonic89
would this work?? just an idea i had
Turbos are not sized only by displacement and they aren't referred to as "1.8T Turbos". For example, the VW 1.8T uses a K03 turbo with an application specific turbine housing.
You would need to fabricate your own exhaust manifold to mount the turbocharger, lay out intake/intercooler piping, review/redesign your vacuum system to handle boost, provide increased fuel support (flow, pressure, and ecu tables), and rewrite timing tables to keep from detonating.
That is a very general overview of what it takes to put a turbo on a naturally aspirated car.
ok is it possible tho?
Or, if you really want a turbo on it, go for it. Don't listen to these naysayers about, you should've gotten the 1.4T, blah blah. A turbo on the 1.8 will net you WELL over the 138 hp that the 1.4 is good for.
And just to preemptively stop the person that's going to say, "That's before you tune it." The 1.8 will make more power. The 1.8 will make more power. The 1.8 will make more power.
-Eric Smit
hey eric can u help me out??
