ChevyST_12
Nice video btw man, haha and thanks for making the list btw.. oh and question how do you get to the front interior lights? by the mirror to change them out and same for the rear how to remove them..
OK, so I redid the signal resistors today. I replaced the 3 Ohm covered resistors with 6 Ohm uncovered units. This allows a better fit behind the tail lamp assembly and corrects the unneeded resistance I was putting on the system.
Thanks!
Nice! Did you get the same bulbs I did?
Yes got them from the web site same # you told us about order took 4 days to come in and took me a bit to figure out how not to brake the bracket holding the front interior lights in . then it was easy peasey after that . I am holding off on the head lights until I can afford them but they are next on the list and fogs also . Thank you again for the info the head lights are about 1/2 as much as the ones I put on my truck . the kit for my truck from V-led's
is 1/2 of what I already paid for my old lights
Looks good, but doesnt look lowered to me. Lmao.
Slow down with the mods dude, let the rest of us catch up!!!!
Andrew, can you describe any differences in ride and handling when you switched from the 15s to the 17 inch wheels?
Have you remove the chroom strip at the side window? on this pics i don't see it and other pics i see it!
Yep, I replaced the chrome beltline moldings with the black ones.
Interested to hear more about this. Where did you get the black moldings? Cost, etc.? Thinking about replacing all the chrome on my car. -Thanks!
I'm not lowered, that's just how perfect the stock stance is on 17"s.
Here is the list of exterior LEDs I'm using:
Front Parking/Signal/Side Marker: PLATINUM AMBER 7W HIGH POWER 20 LED PARKING/TURN SIGNAL BULBS 7443 7440 | 1 PAIR
Tail/Brake: PLATINUM RED 7 WATT HIGH POWER 20 LED BRAKE LIGHT BULBS 7440 7443 | 1 PAIR B/O
Rear Side Marker: RED 1.5W LED BULBS W/ DIFFUSING LENS 194 168 158 | 1 PAIR
Rear Signal: PLATINUM AMBER 7W HIGH POWER 20 LED TURN SIGNAL BULBS 3157 3156 4057 | 1 PAIR
Reverse: 5K WHITE 19 LED 8W HIGH POWER BULBS 917 918 920 921 922 923 579 | 1 PAIR
License Plate: 5K WHITE FLANK 1W HIGH POWER LED BULBS 194 168 158 | 1 PAIR
how do you like the reverse lights ? visibility out the back at night is pretty bad , are they significantly brighter ?
You spotted the mod!
Oo don't you like the chroom strip?
The reason why i buy the LTZ is that it has in Europa the chroom side strip and the rings arround the front and rear lights! when you buy the LT than it has now chroom!
can you also buy the chroom strip at the window?
the dad of my girlfriend has the aveo with out the chroom parts and he like it to.. haha
Just curious; is there any reason why you went out and bought the black strip below the windows instead of just plasti-dipping or painting the original chrome strip?
Suggestion for you Andrew:
MkVI GTI Cornering Lights - YouTube
Of course, you'll probably find it easier to do with just using the turn signal to actuate than VWs keeping track of the steering position to turn them on...
Otherwise, great stuff...you are quickly becoming the lighting expert here
Also, are those Cruze wheels chrome from the factory? If so...hawtness...cost?
