$ub$onic
The Sticker Guy
The dohc 4.6 is a amazing engine but sadly the 03-04 block is the weaker of the engine the 93-98 Lincoln markviii had the better engine block . 6 bolt main caps and the early ones where made by the same people who make Ferrari engine blocks . There is a company that builds the early blocks and by a simply boreing it out the a 5.0, cams, pistons can easily hit 500+. And the 93-94 Lincoln cranks can handle 1200hp . Everything about the engine design screams power
And once you add forced induction . Might as well forget it. The power these little motors can make is off the charts. There are a ton of them in the 8 sec 1/4 mile range
