GeneralZod
Yeah saw that, I also owned TDIs with some of the worst dual mass flywheels. I wouldn't go back either.
Much of what I am getting at deals with this... When you start going really light, some dynamic things happen. One of the biggest issues is the weight is on the outer edge of the disc, or flywheel. Add heat and speed variation you can get oscillations in the flywheel. They might not even be visible, but enough.
If the clearances work as the flywheel is static, there could be issues while in motion. This is one reason why they went with heavier, dual mass flywheels.
