firstorbit84
aveo in jakarta is 4-lug?? what's the bolt circle?
That is correct.
The preceding discussion was about what patterns make food candidates for redrilling to 105, to widen the variety of wheel choices that can be used.
5 x 100 and 5 x 110 are much more common and are acceptable patterns to have drilled to 5 x 105.
4x100
4x100
Need an advs from you.. Whats the best size of spacer can i use to get the flush look?cherrs!
ok most wheel companys dont make wheels in 5x105 because the market is to small. other than the new sonics and cruze opel is the only other cars that have the bolt pattern."
My point is, if there is already a set of holes in your wheel where do they redrill?
Im sure you could if you wanted. ANother option would be to have your stockhub and rotor redrilled for a different pattern. I have debated doing this before.
Rotiform and 1552 wheels are generally cast or forged as blanks. They are then drilled to whatever pattern the customer requests.
It would be nice if more manufacturers did this, but Rotiform is quite a bit smaller than other companies so it's probably easier for them to be more flexible.
if you order direct from rotiform you can get whatever bolt pattern you wish, it just costs a little extra $$.
assuming your wheels have the same dimensions, a 19mm hub centric adapter.
