no they dont but the top bolt hole for the knuckel in the coils dose give you the room to adjust camber. are you talking for stock struts?
Yeah, sorry I was referring only to the stock struts.
Sorry if this has been explained elsewhere but i just got 2 of the camber/service bolts: PN:11561297. Is the nut any different from the existing one on the car? or do i need to purchase a specific nut?
-Thanks in advance
i aligned mine by taking a reamer an elongating the holes for the upper bolt it works till i get my coilovers but may not be a permanent fix especially if bolts are only 10 bucks
i use a Snap-on Carbide reamer same one i used for the last 5 years and it still cuts like new.That's a fast way to trash a ream.......
That's a little different then. I hate working with carbide. Well machining it anyways
I have slightly negative camber with my b&g but it is fine. I would assume theres would be the same
is camber adjustment necessary with eibach springs?
