christion
I HATE the way you have to adjust the fade on the touchscreen. It's this stupid dot that you can move around anywhere on the picture of the car and it's really difficult to deal with. I just want a simple back/front fade setting. On to the questions. I know that some of you aren't satisfied with the sound system, but if you're coming from an aveo, this 6 speaker sound system is HELLA better than the aveo's 6 speaker. The bass can vibrate the seats and isn't strained when turned up high. If you wanted any bass in the aveo, it sounded like a frog or something. This bass is smooth and strong. Sometimes the front speakers can sound overly high with too much treble, so I'm wondering if you guys have a setting you prefer that fixes this and gives a little more sound in the back. I can't decide if I like it better when the dot is right under the intersecting lines, or if it sounds fine with the factory settings. Fading it slightly to the rear seems like it makes the overall volume less capable, but it's also not so high up front. What do you guys think?
