In my thread on adding a catchcan, you can see the valve cover side of the PCV system.
http://www.sonicownersforum.com/forum/t1446/
The tube does not pass through the intake on the rear of the engine, but terminates right before it in a fitting that enters the valve cover area from the side.
Not sure what tube you are looking at, but take a look at my pictures and you'll see where it starts.
Hey Danny5, I just ran out to my car to make sure I was not going crazy...
Either our 1.4T engines are different or you are mistaken. I snapped some pictures. Camera phones are awesome!
The PCV does not terminate in the valve cover area. If you remove the 'Ecotec' plastic cover, you'll see it's no where near the valve cover. You may be confusing the PCV hose with the wire harness that goes under the plastic cover. See pictures
The PCV line goes into a cavity in the intake manifold.
Please do not misunderstand me, I am NOT saying the PCV line goes into the intake flow. It goes into some kind of cavity between intake tubes #2 & #3.
My theory is they molded a cavity into the plastic intake manifold which covers a hole in the back side of the head between intake ports #2 & #3. This hole is open to one of the passages that lets oil drain back from the head to the oil pan. Maybe this cavity has some baffles which act to collect the oil mist so the oil, which would have been lost, can drain back into the oil pan?
