AndrewGS
Ultimo Hombre
And you're doing 215s to get a light stretch so you clear your fender openings, correct?
Yep.
The adapters came in today. Here are some photos of the fit without tires.
18"x8.5" 56mm Offset with 25mm Adapters
So if i wanted to run say a 17x8.5 +56 wheel, im gonna need about a 25mm spacer it seems
how wide of a tire could i run on a setup like that? right now its stock rs height. I may put coilovers on it but it wont be maxxed low.
id really like to run a little taller tire too actually, i dont have a problem rolling the fender. a 245/45/17 is what id really like, but i feel like to do that id need an adapter less than 25mm to tuck the wheel in a bit more and clear the fenders, which could result in issues with inner clearance.
any input?
call the tires fat. i dont care. haha
I was looking at these rims on ebay (just looking for ideas, and I realize they'd need to be redrilled)
18x8 G503 Wheels 5x100 114 3 Black w Red Rims Fits Eclipse 1989 Present | eBay
and I'm confused by the sizing because of the lip. It has an ET of 40, but then it also lists a 2.5" lip (which is obvious). However I don't understand how other rims that don't have a big lip can also have an ET of 40 while the spokes sit much flusher to the top of the rim. Something like this:
18x8 Black Red Ruff R355 Wheel 5x100 5x114 3 40 Offset R355HK5BF40O7R | eBay
Any help getting my head around this would be great, because I like the idea of a lip, but want to make sure I can fit whatever I end up getting.
Could someone please tell me what size tire I should run with my new 17x7 wheels?
I want a good stretch look but not to much
Looking at purchasing falken fk452 225/50/16, would I have a problem using these on the stock LT rims?
Not gonna fit (throw off the speedo and you'll have almost if not any gap which could cause issue. My winters are 215/50/17 and they erase all gap (I'm on eibachsMy mom took her stock tires off her subi crosstrek. I can have her "old" tires (1,500) miles for free.
Tire Size : 225/55/r17
Will these fit my sonic ?
17" LTZ rims
Eibach springs
Thanks for the help !
