Kegsandeggs
this is my first post on DIY...got tons of pics... this is my 2013 RS fmic swap with the cx racing kit. Very simple if you dont have an rs...this kit seems to be built for the ltz... because the fog lights come down farther and rub on the hot and cold side, so some slight modification has to be made to the bumper fog light housing. took about 2 hours total. ... any questions, feel free to ask.
Step 1: remove bumper
Step 2: remove all old rubber hose and ic
Step 3 (RS ONLY) remove fmic crash bar (will make sence later)
Step 4: mount new fmic using hardware used to hold up the skid guard
Step 5: work from throttle body back, also easier to attach all of the cold side and wiggle it threw
Step 6: instal hot side
Step 7: wiggle everything straight
Step 8: tighten all of the bolts and t clamps
Step 9 (RS ONLY) you need to shave down the lower parts of your fog lights because the new pipes are a more dirrect air flow and don't have the same bends and twists as the rubber hoses, lots of bumper movement and cuss words will be used in this step.
Step 10: attach bumper, take pics, RE TUNE!!!, smile and have a beer! (Or soda if under 21) you now have a bad a55 fmic, I do not recommend removing the lower grill, that would be dumb. Rocks hit that
