sx sonic
anyone have nitrogen in there tires and if so is helping with your gas mileage? pm's are welcome as well.
Put simply NO.
Almost as simply..... Not if you keep your tire's properly inflated. tires filled to the proper psi with nitrogen will get the same mpg as tires filled with the same psi of normal "air".
To briefly explain it..... Nitrogen comprises ~70% of the air around us with the rest being oxygen, something something, and traces of other crap.
The parts that aren't nitrogen are for the most part smaller in molecule size (like finer sizes of sand or rock) and will 1. slowly permeate, aka leak thru rubber....... OR if you never check your tires it will eventually go flat and 2. are more susceptible to changes in temp. Which as we learned in chemistry as a gas changes temps it increases or decreases in volume. Confined in a sealsed space means cold temp = less volume, increase in temp = more volume..................... no volume in a tire = flat tire.... lots of volume = really really inflated tire.
So the benefit of "Nitrogen" is that it leaks thru the tire substantially slower than air, meaning if you suck at maintenance your tire's will stay inflated way longer.....
AND PROPERLY INFLATED TIRES WILL ALWAYS YIELD BETTER GAS MILEAGE THEN UNDER INFLATED TIRES... From what I've seen car tires below ~30 psi result in significantly worse gas mileage and much worse tire life
Another benefit of nitrogen is it is inert which again we learned in chemistry class means less susceptible to temperature, and other scientific crap. Real world this means it tire psi doesn't go up and down with temperature changes....................... Which is HUGE in the winter, people that don;t check their tires usually have under inflated tires during cold snaps. Which of course means worse MPG and tire wear...
This also means the tire psi doesn't change as much during driving as the friction from the tire = heat which increases tire psi......... this doesn't really matter unless you're a race car driver or landing an airplane or space shuttle. And to be honest would result in fractionally worse mpg since a tire inflated with "AIR" (70% nitrogen) will go up in PSI as the car travels down the road and over inflated tires = better mpg........
