Kegsandeggs
Hello again, this is how i did the boost gauge install. Didn't use the green and black, i have fat arms, so i used the brake boost line, bought a new hoes, teed off of it, ran the vac line threw the firewall, drilled a 2" hole in my dash (didn't do the whole, removing the dash thing), and wired the light to the light switch (instead of the cig lighter) using wire tees to the black ground and yellow DRL wire. Shortened a 3 hour job to about 30-45min total...here are some pics. also i did not use that hoes i teed off, it made the gauge bounce a lot, i switched to the small clear one... enjoy! #TeamRS
