$ub$onic
The Sticker Guy
Is Glow Shift made in America?
I prefer Auto Meter.
Probably not. Cheap as ****. But they work
Hey derp, in regards to dropping the subframe for the sway bar. What needs done with the a arms ?
But you're also saving your time as well. I know you don't mind swapping out the transmissions though, plus you've become quite proficient at it.
That's assuming it will last 4 years with the power he's putting out. If it doesn't its a losing proposition.
It's all an assumption until someone does it and as Preload said, it's just too expensive. Maybe one day ZZP or DDM will take on the project and beef up the transmission.
That was the point I was trying to make. To shell out that much money to try something for the first time is a bit too risky for the average persons wallet.
