Thaifight-R
Pika Pii!!!
I would recommend double checking just to make sure. Some wheel manufacturers have the multi lug for aesthetics. (thus still making it 1 bolt pattern)
I would go with a 205 wide tire that matches the stock tire hight so you're not messing with speedometer.
205 60 15 is the way to go
edit:
i think the stock height is 65, would 60 be better / worse (dont care about the speedo part)
Anyone know the widest wheels made for our bolt pattern? Biggest I could find were 18x9.5
Only problem is they're all ugly wheels. I guess I could get some wheels redrilled but it's hard to find the right wheels that will have room for a redrill
I'm trying to get stretch but I have like 7.5 wheels so it's damn near impossible. I love my wheels though just wish they were wider
65 is not the height, it's the aspect ratio, as you may know. But just to clear it up for those who may not know... The aspect ratio is a percent of the width, not an absolute height measurement.
A 205/60-15 will be shorter than a 225/60-15 even though they are both a 60 aspect ratio because 60 percent of 205mm is less than 60 percent of 225mm.
Which likewise means that 205/50-17's are virtually the exact same overall height as a 225/45-17. The lower aspect ratio (45 vs 50) is almost exactly offset by the greater width (225 vs 205).
Another example would be a 205/50-15 will have an overall height which is two inches shorter than a 205/50-17 because the wheel is two inches shorter even though the other numbers are the same.
So in summary, when talking about overall tire height, you can't really talk about a single number from a tire's size because they all have an effect on height.
someone in this thread had directed people to discounttire.com (thanks for that) - but im still a little confused. at that website, i found some Falken Ziex ZE-512 --- 205/60R-15 91H B - that i liked - looking to slightly decrease the sidewall size and increase the width. was also looking at some other ones, but were scared away because of lack of reviews.
as far as my driving habits are concerned, i have had the car since nov 2012 and have about 52000 miles on it. sometimes i like pretending i have a racecar... lol
awesome. thanks guys - much appreciated. and this would fit nicely on the stock rim?
edit:
I wouldn't go with the falken 512s
I'm one of the managers at dtc and those tires are junk. If your wanting to get a good tire pay and extra 15-20 dollars more a tire and get something that will def grip better and last longer. Yok yk580 are a great choice.
