Yes and no. It was the 90deg elbow that connects to the BPV but I'd had it hooked into a T-fitting so I could install a boost gauge for some bypass mod testing. It wasn't intended to be permanent and was assembled as so. Didn't hold up to the several hundred miles I wasn't expecting to have it installed for.
Nothing to be concerned with the factory plumbing. But if you hear weird blow off noises when chopping the throttle It's either a popped off BPV line or an improperly done Bypass mod.
Just making sure it wasnt the hard plastic line.
Third pedal for life!
