Well, I'm back at the dealership today. This will be the 6th unscheduled visit.
1: Wind noise coming from rear hatch area. Turns out it's in all Sonic hatches, just need to put some weather stripping at the top of the hatch seal. They also replaced the front sway bar links
2: Rear noise/rattle - they said loose spare tire...um..NO
3: Leaking axle seal - fixed
4: Same rear noise/rattle - replaced shock
5: Same rear noise/rattle - replaced shocks and mounts, still not fixed
6: Leaking coolant and same rear noise/rattle - in the shop now.
I'd put those Moog stabilizer bar links on the front, and the shop foreman was wavering on voiding the suspension part of the warranty because of that. We talked and I think they'll still honor it. I told them if they wanted I'd put the old OEM links right back on (still have them, they actually look fine), and that I only put the Moogs on to see if the front noise would go away (it makes some noise too...) it didn't make it go away.
Anyway, the dealership is going to work on the leak, hopefully I'll have it back by Tuesday.
It's going to snow all hell this weekend too...crud!
