sonichead94
awsome. get some pics of it when installed.
Getting ready to install an Alpine Power Pack (KTP-445U) into my Sonic with Mylink.
1. How much lead do I need to mount the PP behind the air con controls. The amp came with about a 2 foot lead on the output end. Is that enough?
2. Can I grab power off of the factory harness (yellow wire)? Is the circuit capable of running both the head unit and the amp? (I have a feeling this is a dumb question but wanted to ask anyway)
Note: I also bought a PAC AA-GM44 just to use the harness. I didn't want to cut into the factory harness, so I bought the PAC so I can wire everything on my desk and plug it all into the factory harness. I plan on just cutting the LOC off since it's redundant.
3. Do you think I'm being too anal? (That was a trick question, please don't answer)
Never expected a response THAT quick. Good to know you have a special hotline. I'll try not abuse it.
Yeah, the input side is going to need some extending. I s'pose they have a good reason for making it so short.
Heading for my local radio shack to buy wire and stuff. Haven't done anything like this since I was a kid -- a very long time ago. Should be fun.
Thanks again!
What color are your rims? Is it that "intense teal" plasti dip?
Sent from my SGH-I747M using Tapatalk
The passenger side just pops off. Just needed to give it a determined pull on the shifter side of the panel. Once that end is released then you slide it toward the passenger seat and a tab thingy is released at the top and voila -- off comes the panel.
Seems there's all kinds of space behind the panel. Glad the panel comes of so easy so I can adjust gain on the amp after installation.
