ReeseLightning
The car was bought June 28th
Already installed a few mods but I'll bring everyone up to speed.
First thing I did was install a set of NRG pedal covers.
Next I ordered the CAI and shifter bushings from DDMW.
Here in Pa we aren't required to have a front license plate and that cheap piece of plastic is an eye sore so one afternoon I drilled a 1/4 " bit through the rivets and ripped it off. Then went to my local ACE store and picked up some 1/4" plugs to fill the holes.
After that I personally installed the short shifter from DDMW as well as the shifter weight which followed a few days after that.
Side note: I'd recommend putting loc-tite on the bolts of the shifter weight before installing. Recently I opened the hood to find the bolt was completely out of the short shifter assembly. To my surprise the bolt wasn't lost and was still on top of the engine block, I will be putting loc-tite on it to prevent further incidences.
I'm very scientifically oriented and as I was browsing through some threads I came across a neat device with some readouts on it. After further investigation found out this device is called an ultra-gague and ordered one right away.
Next and easiest mod by far was the removal of the snorkel, wasn't only free it wasn't hard either.
Today my TTR Engine Mounts arrived !!!
