Interesting there with removing the tape. It looks great on black, but I wonder how it would look with my silver? Probably like an early to mid 2000s VW Jetta?
I wish that I could post" I opened my hood and they accidentally stuck an experimental 2.0l twin turbo in my car". It sounds a lot better than" They stuck the Sonic emblem on crooked on the trunk lid".![]()
They did that on my car. I opened the hood and there it was, a stock 300 hp motor. I said that's to much and took it back.
The first time I replaced my 2013 Sonic cabin air filter myself, I had noticed that every weld joint visible with my flashlight , inside the dash, was already rusted. After the metal supports are welded you would think something could have been applied to them!
Alrighty so after reading this forum for a bit I finally had the guts to remove my black tape on my 2013 Sonic Sedan and boy does it look awesome.
Alrighty so after reading this forum for a bit I finally had the guts to remove my black tape on my 2013 Sonic Sedan and boy does it look awesome. For those of us who dont know how to remove the tape heres a "how to".
First off what you need:
A kickin heat gun
Goo Gone
Tweezers or needle nose pliers (the smaller the better)
Some patience
And lastly some dang good music.
1) Turn on the music (your going to need it lol)
2) I started with the drivers side front. So take your heat gun, turn it on let it preheat up
3) take the heat gun to the inner door edge where the tape begins and lightly wave the gun over it being careful not to over heat it
4) Now you should have a corner starting to peel up a bit. Grab it with your hands and start pulling
5) as you go you will have to stop to heat the door edge up for the section that you are peeling back on. If you dont it will make life a living heck. (trust me I tried it lol)
6) This is the tricky part. The tape does go under the weather stripping on our cars. But I found the trick. Heat the area up on the outside of the window. Once you get it nice and warm take your device of destruction or better known as tweezers or pliers and pull gently. (this is the part where you will need patience.)
7) So after all the tape is off take a paper towel and put a tiny dap of goo gone on it and wipe off the glue (if there is any)
So if you repeat this for all four doors you should end up with a nice shiny black door edge!
Hope this helps!
Ok, let's get one thing (straight). The Sonic is not junk and before you come on this site and start bashing the car that this whole forum is about you need to think about what (you're) saying and not just open your mouth and talk ****
It helps if you quote the person you're ranting to.
no i don't have to quote that person because that person knows who he is, he is not dumb
