They work. I have an auto trans with the TTR Mount.
Do you also have the upper engine mount? And how complex was installation?
It's easy.
Basically it is:
Jack under oil pan to support engine.
Remove intake box
Unbolt from engine
Reverse to install.
And the trans mount is equally easy?
I know the tread is a couple months old, but I have a Sonic 1.4 turbo automatic and the tranny mounts do work. It is the Upper engine mounts that are different. I purchased a ZZP upper mount, and they were not sure at the time if it worked on an auto, the answer is No.. They refunded my money fully with no problems! (they look very similar but bolt up completely different)
