Ontario Sonic
Hey all, i took a look around the forum and couldn't find a thread that covered this issue, at least not all the parameters of it so i created a new thread and i hope you can help me figure this out.
I've had my Sonic for about 6-7 weeks now, and as far as i know this sound wasn't there when i bought it. I noticed a couple days ago when i pulled into the drive way, i got out of the car before i turned it off and i noticed a slight high-pitch whistling sound. Now, when i am in the car i can not hear it at all, driving and everything all sound normal and the car is running perfectly fine with no issues. The sound only seems to appear when i am parked and every time i have heard it, all HVAC systems were off and the car was at idle.
I am not losing any coolant and the water pump seems fine (others on the interweb seemed to point to coolant loss as a potential culprit) and it does not seem to be coming from any of the pulleys in the serpentine area. Another discussion i read for someone having a somewhat similar issue to me one of the respondents said that it might be the turbo wastegate letting off pressure or something to that effect, and that it was normal, so i'm not sure. All of my previous automotive experience has been with 3800 series II engines as all my previous cars have had them. So little 4 banger turbos are a brand new experience for me and i'm not sure what all is normal yet.
I've included a video i took this morning of the sound, and it seems like it might be coming from one of the lines in the back left of the engine bay, up against the firewall, although i may be mistaken as sound likes to trick you in tight spaces like that.
If you want to watch the video and give a listen, maybe one of you guys can help and tell me if this is normal or abnormal.
It is important to note that the mic on my phone really picked up the sound and kind of blew it out of proportion, the actual whistling sound is probably 25%-35% quieter than it sounds on the video, if that helps with diagnostics. Thanks in advance for any help
https://www.youtube.com/watch?v=faUsRo-hncE
