radsonic08
I got it put limo tint on your front Window so you don't get blinded by non projected hids
The main issues I see with adding HIDs to the fogs is heat and power.So I went through this thread and it was not very helpful. Probably because I don't really know much about lighting.
Can someone tell me what else I need with my HID kit for my fogs? I read that the factory wiring voltage is too low and that I need something else to make it work?
I just need a link. Thank you!
Heat: HIDs put out much more than the stock halogen so you may melt the housing. You could retrofit a tiny HID projector into the housing like the matchbox which is just under 2" dia
https://www.theretrofitsource.com/c...-xenon-fog-light-projectors.html#.VrQImJ9lDqA
Power: you can drive relays with power running straight from the battery, using the stock power to activate the relay which will power the ballast cleanly. If you're not concerned about the heat and run HIDs in the stock housing this set up would make it nearly plug and play for the H8
https://www.theretrofitsource.com/hid-systems/morimoto-elite-hid-system-h8.html#.VrQKEJ9lDqA
.....drive it like you still owe the bank money
Stock headlight housing?![]()
I have Diode Dynamic HID's in my 2015.
Love them
Sent from my ALCATEL A564C using Tapatalk
Nice. Will look into those for the future.Yep.
They are not cheap HID's
They end up being $180 with the relay setup.
I saw that, I am debating on not even messing with buying the relays and just buy some yellow halogen bulbs.. I'm not sure I want a crap ton of wiring down there!
