RockTheShazbot
DISCLAIMER: I am not responsible for any damage cause to your vehicle. If you don't feel comfortable doing the DIY shown below, then take it to someone you trust to work on your vehicle.
Difficulty: Easy
Time: 15-20 minutes
Mind the mess, but here is the before picture.
Locate the four plastic push tacks (or whatever they are actually called) that you will be removing for the cargo net.
Next, locate these bolt hooks. There should have been 4 of them.
Remove the four plastic push things (this will require a bit of force, don't worry if you break them, 1: they are like $2 for a 4 pack at Autozone and 2: you're going to be replacing these anyway). The hook bolts just screw right into the holes that the plastic things were in.
Hook in the cargo net
All done!
Side note:
Make sure to reset trunk lining to prevent any damage to the seal and just for overall looks.
Difficulty: Easy
Time: 15-20 minutes
All done!
Side note:
