If your car does not require premium gas, there are no added benefits to your car’s performance or longevity. Simply put, you’re paying good money for something you don’t need. Premium costs 15-30 cents more a gallon than regular. In a consumer notice, the Federal Trade Commission, notes: “In most cases, using a higher-octane gasoline than your owner’s manual recommends offers absolutely no benefit. It won’t make your car perform better, go faster, get better mileage or run cleaner.” Enough said.
If your car requires premium gas, using premium will allow you to optimize your car’s power. You will not achieve the advertised horsepower on a vehicle that requires premium unless you use premium, although most consumers will not even notice the change in power when switching from premium to regular.
And, something else to consider: Six automakers, BMW, General Motors, Honda, Toyota, Volkswagen and Audi, believe using Top Tier Gasoline that contains a higher-percentage of detergent additive from that required by the EPA standard, provides optimal engine performance. They claim that lower concentrations of detergent additive lowers the quality of gasoline and can leave deposits on engine parts, such as fuel injectors and intake valves, which can lower engine performance, vehicle responsiveness and increase emissions. BMW, General Motors, Honda and Toyota developed the Top Tier standards under which gas retailers must meet in order to qualify as a Top Tier gasoline retailer.
