Reset your mpg reading lately? It's computed on average so if you're getting better mpg lately the average is only slightly improving
I reset mpg trip and avg speed every fill up
Because more engine knock produced with the no ethanol fuel(data logged thousands of miles) the MPG loss with 10% ethanol is nowhere close to 3%. a few stations in my area sell both 91E0 and 93E10 from the same pump(different hoses). I filled up at the same pump week after week and compared the two....
I saw only a 0.8MPG improvement once I averaged every fill up with the no ethanol fuel, so it wasn't worth the extra 10-20cents a gallon over the comparable 10% ethanol 93 octane fuel.
You do realize that without the ethanol, your mileage will improve by about 3%.
"Actual results will vary for many reasons," says the fine print below the EPA gas mileage on any new car's Monroney sticker. The sticker then lists a few of them: driving conditions, driving style, vehicle maintenance.
There's one more: ethanol.
These days more than 95 percent of gas sold is E10, said AAA spokesman Michael Green. E10 is 10 percent ethanol and came into use after amendments in 1990 to the Clean Air Act, according to the Department of Energy. All cars are certified to run the stuff; in fact, it's difficult to find ethanol-free gas anymore.
Yet the more efficient ethanol-free blend is what the EPA uses to produce gas mileage figures posted on that new-car sticker.
And there's the problem. Ethanol's lower energy density leads to worse gas mileage, which is why using E85 (85 percent ethanol) in cars that accommodate it is usually a bad idea.
The math carries to E10, which has up to 10 percent ethanol. A gallon of E10 has 96.7 percent of the energy in one gallon of gasoline, according to the DOE's Alternative Fuels Data Center.
That means E10 fractionally lowers real-world gas mileage. How much? Try about 3 percent, said Toyota Senior Energy Researcher Mike McCarthy and Ford powertrain spokesman Paul Seredynski. AAA's Green and the EPA both pegged the E10 loss between 3 and 4 percent. That means a car that sports a 30 mpg EPA combined figure is already hampered from achieving that number. The starting line is really 29 mpg.
Read more at https://www.cars.com/articles/2013/...ry-for-the-worse-ethanol/#Ayflpfl4wxgACB5e.99
But I know that there is less energy in a gallon of E10 vs a gallon of E0. It's not much - just about 3% - just like I posted.
So what is your average speed? Its really telling of how much idling you are doing. Summertime with 80% highway my average speed is usually about 42mph or higher. In the Wintertime with 100% city driving and tons of idling I've seen my average speed as low as 15-20mph.
The energy content of the fuel doesn't always tell the whole story, Exactly why I mentioned Testing done on the Ecoboost F150 gets better MPG on 93E30 than on 91E0. The reason? No ethanol fuel causes more knock events(you can compare 87E0 to 87E10, 91E0 to 91E10 in your sonic or any other modern turbo car to see this) which causes the engine to dial things back when you need the power the most and will effect your MPG.
Even though the EPA testing is done with no ethanol fuel, Daily at 45-70mph I easily beat the EPA highway rating with my sonic with E10 or E15 fuel. According to the energy loss you mention I should not even be able to achieve that MPG. I average 40mpg highway even on 15% ethanol(90 octane fuel).
Last I heard Alaska only has 90 octane no ethanol fuel available, so the OP unfortunately has one of the crappiest fuels available for the turbo sonic. With no ethanol fuel from my fleet testing these cars can get worse MPG. There is a Cenex in Middleton,WI that has two sets of islands, one with and one without ethanol. They offer 87E10, 90E10 and 93E10 on one and 87E0,89E0 and 91E0 on the other.
87 and 89 octane no ethanol could at times cause severe knock events 91 not as often but still could occur. Funny part? 90E10 mid-grade preformed better than the 91E0 at a significant price reduction. Heck even the 87E10 outperformed the 91E0 in controlling engine knock. We tested this on a fleet of (40 drivers)20 Cruze with 1.4T and even tried using different brands of fuel and found the same results. In hot weather or just dealing with heatsoak(city driving) we saw MPG loss across all cars and drivers when using no ethanol fuel of any grade.
So unfortunately that no ethanol fuel the OP is using could be contributing to their low city MPG especially if the outside temperatures are above 80F.
2014 RS 6speed. all stock 30k
So I'm getting pretty terrible mileage I'm averaging 20 mpg I have verified it through a dozen fill-ups.
I do A LOT of city driving, round 100 miles a day. I do drive the car pretty hard but mostly just accelerating, once I'm at the speed I want I just cruze'.
However even driving very gently, or as gently as I can before I feel I am a burden to others on the road, I still only manage 22.mpg
Highway I managed 35mpg
The only things I have done is new tires(235/45/17) and a K&N drop in panel.
Mpg was the same before both changes.
Tires are at correct pressure. They were actually over filled to 42-3 psi, I put them back to 35.
Anyone Have any thoughts? could it really be time for sparkplugs??
Probably the biggest factory with city economy, especially with a small turbo engine, is how the right pedal is used. A couple rips up to speed will decimate your economy average. Idle time will also have a big impact. If you sit at lights a lot and then take off fast when it goes green you will never have decent economy.
I agree fully. Sure, a 1.4 doesn't burn much gas, but 14.7psi on a 1.4 effectively makes it a 2.8... kinda like double the displacement.
If that were true it would be getting better mpgs. My 92 Taurus SHO with the 3.0l v6 would easily pull 20 mpg driven much harder.
Sorry, you clearly have all the answers already.
