No tune.
MPG 23, down from 34-35.
I'm guessing the K&N filter dirtied my MAF sensor with oil? Or the intake tube before the MAF is too short causing turbulence.
Sometimes the car really goes and the very next launch it will take minuets to get up to 25.
I bought on a whim.
Eeek went down to 14. Started to raise slowly to 16.
Gotta find a coupler and go back to stock. Unacceptable!
Was at 8 MPG, I could smell a lot of unburnt fuel.
Turned the car off for a bit, then went for another drive.
Went from 14-16 up to 19 mpg. So maybe I'll hold off from reverting back to stock just yet.
Still a lot of gurgling and hiss noises. Every now and then a swish.
Bought a DR. Pepper to make me feel better.
I just dont want to kill my poor car. Melt the cat from overly rich or build up too much carbon from bad combustion. Lots of negatives running through my mind.
EDIT: reverted to stock, but still getting bad fumes/running especially at idle. Gets around 28 freeway.
I hope it improves more. I gotta drive from TX to Baton Rouge.
This is what happens when I have the day off work.
UPDATE:
I cleaned the MAF with CRC. Epoxied the Airbox together. Tomorrow I will take a look at the plugs and possibly consider checking the 02 sensor if that is even a thing I can do?
Been driving in Gmode and still barely into the 30mpg range.
Update 2:
Milage is better after cleaning MAF with crc. Getting around 34 where I was before. Still more sluggish off idle and rough at idle.
My filter got repurposed.
