Suprnova74
After fixing (and cleaning up!) my failed valve cover gasket that sprayed out at least a quart of oil all throughout the engine compartment, I thought I had my leaking issue resolved.
Unfortunately I now have a new leak. A reddish fluid leaking from center towards passenger side. I thought at first it might be power steering fluid but as Sonics don't have the traditional power steering, that's not it. The only culprit left would be gear/trans fluid? It's a manual transmission. I haven't jacked the car up to inspect the underside yet. Is my hunch probably correct in that it's most likely manual trans/gear fluid?
All I know is I'm running out of fluids to check. It's not brake fluid. the amount on the floor would have left the brake fluid reservoir much lower and it's fine.
the good news, if there is any, is the fluid doesn't smell burnt!
2012 Chevy Sonic LT Turbo Manual Trans ~150k miles
EDIT: Added pic of the fluid. This dropped after about an hour being parked.
