My usual average is 5.2L per 100KM (Which converts to about 45MPG), all city driving. Worst has been 6.0L per 100KM (39MPG) which was bad stop-and-go, while my best has been 4.7L (50MPG) on a day with no traffic.
i'd like to know how the &^%*&% people get this ridiculous high mpg (intown)
No? I don't floor it (Usually), use a bit of common sense with predicting and maintain my momentum through corners, but nothing that's crazy or anything. I'm on a base model, 1.8L and the manual. I mainly just follow the golden rule of fuel economy: Any time you touch the brakes, you've wasted fuel.someone pushing you in neutral????? my 2012 LTZ HB was lucky to get 22~ mpg intown.. just before i sold it . (99.5% town) #*(@^%(&@
and parents 2015 LS base still only gets average of 10.3L/100km according to the dash which is pretty accurate .. and is still under 23mpg .. and thats a 70% city 30% highway ...it only has 25k on it.. so its still a baby ..
Don't know what to tell you man. Reset before each trip yesterday and today. 5.2L in to work yesterday, 5.2L back home yesterday, 5.2L back in to work today.so what your saying is you get roughly 900km to a tank intown based on fact i get 430~ at 23mpg i still call BS .. i could't get that highway tailing a rig with a tailwind going downhill .. i know the manual is a few better but and NO i did not drive the turbo hard, and neither does my 60 year old mother on the LS..
i just dont see the intown rating you got... just can't . unless your traffic is nil and only 1 traffic light for miles..
Ah, that makes sense, because:no requirement that anyone believe anything posted here, but....i posted fantastic mileages and i can prove them. 1) the manual gets better mileage than the automatic. 2) how you start and stop and whether you stop and start makes a big difference. 3) ambient temperature matters. 4) warm up and use of a/c uses more fuel that you can imagine. 5) if your mileage is that bad..... MAYBE there is something amiss in your cars or the fuel you are putting in them. 6) kind of goes without saying ,but.....anytime you are into the turbo your mileage will go down. the automatics that i remember have shift points above the no turbo range...no matter what i did.
Right, no doubt, but the car is also compensating for that - you're not getting a leanout condition in cold air, you're just getting more air and fuel. On top of that, most oils/greases are more resistant to movement in the cold, that denser air is harder for your car's body to cut through and typically cold air is less efficient at mixing compared to warm air. Almost universally, cars get worse mileage in the cold. It's very odd that the Sonic seems to get better.As atmospheric air becomes colder it becomes more dense. Note, the percentages of gases in the air remain the same, but the specific gravity of the air increases. Therefore in a liter of air there are more molecules of air available for combustion. So colder air will improve performance. In fact that is why people install cold air intakes, to provide as dense air as possible to squeeze as much horsepower out of the engine.
That's the way it normally is supposed to go. Hotter air promotes better air-fuel mixing, is easier for the car to cut through, increases tires psi (Which decreases rolling resistance), allows the car to hit operating temperature quicker, heats the fluids quicker and decreases the amount of air available to the engine (Which limits how much fuel the engine can use).don't know why, but the sonic i had responded to temperature. not better in cold, not better in chilly, the hotter is was the better the fuel mileage.
