Smashley23
Some advice from the ZZP team.* All factory boosted engines require premium fuel, even stock cars.* This is a higher compression tiny engine in a car that is a little heavy for it.* It spends a lot of time in boost because its being worked so hard.* Below is a pic of a bone stock Trax piston (The Trax uses the same engine as the Sonic/Cruze) that was daily driven by someone that doesn’t beat on it and was using 87 octane. *What you are looking at is a piston that is broken between the ring lands.* The cylinder temperatures got so hot from detonation or “KR” (Knock Retard) but the piston rings bound up in the cylinder and broke the piston casting.* This causes the engine to burn oil and reduces performance.* A lot of 1.4 owners are driving around with pistons like this and they don’t even know it.
Hope this helps some people out.
Have a great day!
-ZZP
Have a great day!
-ZZP
