Preloader
The M32 Martyr
And so it begins...... Summit White LTZ 1.4T MT.
INSTALLED:
Seibon CF Hood/Hatch/Fenders
E85 Trifecta Tune
42lbs injectors
MZ0 Transmission
CM 11lbs Aluminum Flywheel
CM Stage 4 Sprung 6 Puck Clutch
Ported Intake Manifold
Pedders Coilovers 3" Drop
Polyurethane LCA Rear Bushing
TTR motor mount
TTR trans mount
ZZP Downpipe (2nd bung plugged)
ZZP Midpipe
DDMW Hi-flow 2nd Cat
DDMW Cat-Back no res/ no muff
14" Magnaflow Res
DDMW Short Ram Intake
DDMW I/C Diverter
DDMW Coil Cover
DDMW Turbo Heat Shield
DDMW Hard Charge Tube
Braille CF Batt
Ultragauge
Door Lock Knob delete
DDMW shifter bushings
SharkFin
15/35 Tints
Redline MT90 Trans Oil
Vehicle weight: 2,615lbs.
INSTALLED:
E85 Trifecta Tune
42lbs injectors
MZ0 Transmission
TTR motor mount
TTR trans mount
ZZP Midpipe
14" Magnaflow Res
DDMW I/C Diverter
DDMW Coil Cover
Braille CF Batt
Ultragauge
SharkFin
15/35 Tints
