ok so I got the sub amp and wire kit installed.
I ended up building a ported box. I used 3/4 inch MDF with a 1.5 inch front plate. (Two .75 inch mdf glued and screwed together) then I renforced the seems with fiberglass resien. I used a 3 inch port tuned to 30 htz (a peice of pvc did the trick)
I ran the power for the amp down the driver side, from the batt through the firewall (the soft rubber gromit that the factory wire is going through, behind the break pedal) i didnt bother using any of the grommits that came with the kit. The rubber on the grommit on the firewall was so soft it wasnt needed. I tried to get a pic of it.
I ran the rca and the remote down the center consol under the carpet and back seat to the trunk. This was very easy and fast to do. The best part is ya cant tell i did an install at all. ;D
This system hits HARD. when i first hooked it up i wired it @ 1 ohm the bass was enough to make my chest numb. Only problem is its dropping my volts and causing distortion in the cabin speakers. I took a look at the factory electrical wires to the batt. They look to be 8 gauge so my next mod will be "the big 3" to the electrical, by running 0 gauge from the pos of the alt to the pos on the bat, the neg on the bat to the frame and 0 gauge from the engine block to the frame.
I have been looking for help on this and havnt found much so if anyone can help tnks in advance.
