theenico
Since people are lowering their cars, I thought I'd post how to adjust the camber on our Sonics.
From the factory camber is not adjustable. Neither the struts nor the knuckles have slotted holes.
GM has released special service bolts that can be used to bring a car back into spec. The P/N for these bolts is 11561297. You need one per side and they replace the lower of the two strut to knuckle attachment bolts.
If the desired camber can't be acheived with these, you can search out some 14mm cammed "crash bolts" from the aftermarket. Below is a link to what I am referring to:
http://www.amazon.com/Moog-K90474-Camber-Adjusting-Bolt/dp/compatibility-chart/B000HPQ1EW
