mitdr774
also a dinner prick
I picked up a spare head to take apart and look into what can be improved upon. I can see that I will need a special tool for valve spring removal, but so far no other major surprises. I will update as I get measurements and pull more apart.
Overall shots:
Exhaust port:
Intake port:
Lifter:
Valve spring retainer (well what can be seen of it):
Cam shafts and bearing/caps:
update 1:
Valve information.
Pulled one intake and one exhaust valve and its associated parts today.
To make sense of that picture here are what the numbers are.
Intake valve head diameter: 1.227"
Exhaust valve head diameter: 1.083"
Valve stem diameter: 0.194" (approximately 5mm)
Retainer:
OD: 0.786"
Diameter for locating inside spring: 0.519"
Overall height: 0.379"
Valve spring:
uninstalled height: 1.658"
wire diameter: 0.124"
OD top of spring: 0.781"
ID top of spring: 0.542"
OD bottom of spring: 0.901"
ID bottom of spring: 0.654"
Crude measurement of installed height: 1.404"
Update 2:
Camshafts
Intake camshaft:
Lobe base circle: 1.259"
Lobe lift: 0.395"
Exhaust cam:
Lobe lift: 0.352"
Overall shots:
Exhaust port:
Intake port:
Lifter:
update 1:
Valve information.
Retainer:
OD: 0.786"
Valve spring:
Update 2:
Camshafts
Intake camshaft:
Lobe lift: 0.395"
Exhaust cam:
Lobe lift: 0.352"
