JungloSonic
2014 Sonic a/c compressor seems to go on and off at about 30 sec intervals. (30 sec on then 30 sec off then repeats). Does this indicate anything wrong with the a/c or is this normal. Outside temp was around 20 degrees celcius.
You are soo correct. last night I saw this YouTube video sent to me by someone who knows a bit about cars.Let's start over. The ac compressor was most likely cycling because the fans were not coming on. Refrigerant pressure is related to temperature and both sides are bound by the science. If one side is high because of no fan operation so will be the other, thus the readings you were getting.
The fan has a low and high speed relay as well as a fuse, all of them must be checked to determine where the problem is.
The relays can be bad or not being told to run the fan, you must determine which is the issue to diagnose.
The simple fix could be a burned out fuse. that is where I would start ...
Really sounds like, you need to let someone who knows what they are doing to work on it, in IMO.
