Let me turn the tables, where's the proof it works? So he changed his fluid. Claims it shifts better? Zero data or analysis that the fluid is actually bad. (Realize clutches will defuzz which will darken the fluid, in addition to heat cycling.) Gut feeling is it shifts better? Like I picked up 20hp with a carb spacer plate (measurement via butt dyno)? Perceptions are a funny thing. Doesn't mean I'm calling anyone less than smart. Sure he's a tech. Great. He's got knowledge of other products. Doesn't mean he's an expert with this particular product. This isn't your mom's 4 spd or grandfathers 3 spd.
Where's the proof the fluid was bad?
Bigger questions is, the car is under warranty, why wouldn't you take it in? Take the service manager for a ride to demonstrate it. Specifics of the actions you're taking to induce the condition are critical. People drive differently. Different routes, grades, speeds, etc.
Yes its under warranty but they did the same thing that they do to everyone else push them off. There is not supposed to be a lag between the shifts. I have 2 of these cars in my household one is mine and yes they are identical and the other one has had no such issues. I get where your coming from and if you don't have the issue with your car you won't understand. Would you rather I state that the transmission is a piece of !@## and there is no fix and we are all screwed???? Or maybe there is a simple solution. Maybe it won't solve everyone's issue. Some may have actual transmission issues. Have you never gotten a bad tank of gas before???? Everything gas, diesel, transmission fluid, motor oil, ect all start from the same base product. Crud oil. Judging by manufacturing standards of most vehicles. It would stand a better chance of a simple solution and not a complex over involved situation. I once again respect your persistance but where is your answer. I am very aware of how this vehicle is supposed to behave. I have two to compare.
Question... What do you drive????
Tell me what happens to a transmission when the fluid is too thin??????
If you feel this is not the answer then what is the answer????
I am all ears believe me. Been over a week still no lagging shifts. I once again Dex-6 approved fluid is all that went in. I didn't use some crazy ridiculous !@#$ in there. Dex-6 approved fluid. For those who don't know dexron VI or aka Dexron-6 is the approved Gm fluid in which your transmission uses.
Here is a link to a pdf of the 6t trans that comes with the sonic. Anybody notice something missing that is different about this trans HINT HINT!!!
http://www.automaticchoice.com/Catalogue/6t30.pdf
This is an exploded cut out view for those who dont know what there transmission looks like on the inside.
