I have already bought my supplies for the project, but.. what is regulating boost at this point? Obviously we still have the waste gate but the blow off gives the last bit of control for how much boost. Are the members who've done it, hitting boost numbers higher than intended or does the cap stay at 22.5? Just want to make sure before people blow head gaskets. Believe me I want to install the setup now I just want to make sure
Boost pressure is controlled entirely by the wastegate, it's sole purpose is to modulate boost pressure and shaft speed.
The BPV/BOVs sole purpose is to vent pressure when the throttle is closed.
With out this the boost would suddenly hit a wall that is the throttle plate and try to reverse flow thru the spinning compressor (which may be turning 150k RPM). This is horribly bad for the compressor wheel and bearings.
Now GM may have blurred the line a little bit here but the components still function the same. They just added a little nanny-ing to the BPV. it will bleed off a little extra boost at times to numb power delivery. Much like a super overweight triple sprung flywheel and pressure plate, it's their for the casual motorists that wants to "ride" in a car, not for people that want to "drive" their car.
This mod simply makes the BPV act as it was initially designed for, to vent boost ONLY when the throttle is closed (technically anytime vacuum in the manifold has less authority than the boost psi at the valve). Now when you're WOT the only thing messing with boost is the wastegate.
In fact this is how most turbos are controlled, BPV is hardwired to a manifold vacuum source.
I posted up the gains I found in my 1st post, they're noticeable but not over the top. My initial testing is showing about 8-10hp thru part of the powerband and a smoother torque curve.
