Tommyboy4725
"hottest sonic around" bull****
It looks like it was one of perhaps half a dozen turbo LTZs built before the constraint. I wonder if it came with the five speed shifter knob?
Laborsmith
Yo Danny5, can you take a side view pic at ground level without any downward angle (straight on) from both sides cuz it's very hard to tell how low it dropped since your car is black (the black tires seem to blend in with your current pics). Also, if I have 17" aftermarket rims will the tires tuck under more (less gap) since they're bigger than your 15" stockers or will it be the same?
Not the prettiest picture since it's over exposed for yah
The overall height of the 15s should be the exact same as the 17s.
Installed this morning. So far high speed, low speed, and comfort seem to be unaffected. The rears bottom out faster on large high speed bumps, but I had 600lbs of people in the car on my rough road testing.
Cornering is the same as before, these springs are pretty compliant. I love the look! Rubber air dam is now 4" off the ground.
Anybody know stock height from hub to fender? Apparently I got my measurements wrong before I swapped it out.
I went from 16.5" front to 13.5", and 16" rear to 13". The before measurements are definitely wrong. Any stock height hatches want to measure for me?
Eric, throw some spacers on to push them out a bit until you get your new wheels.
Spacers are expensive! :O
But the thought did cross my mind.
-Eric Smit
Perhaps. I am currently googling.
-Eric Smit
