sonic007
Hey guys. Just did a single din radio in a blue sonic today. Didnt take very long and was pretty easy to do. I have a bunch of pictures I took that ill post up here shortly. Just a reminder you will need a european antenna adapter. The kit does not come with this.
Not responsible for anyones vehicle if you break it...just have to get that out there.
As far as the install is concerned, its fairly simple. The trim around the radio pops off, then theres 4 7 mm screws folding the radio in. Unplug the harness and the antenna plug, thats it for taking everything apart.
The harness has alot more wires than usual, depending on if its amplified or not, has an aux port, etc...There is very detailed instructions that come with the kit so follow that for the harness.
The kit goes together by attatching 2 brackets to a pocket(for single din), then the radio. You have to take the vents off the factory bezle then put them onto the aftermarket one. Just use a flat head carefully sliding the tabs off, then it just clicks into the new one.
Once your harness is completed you have to do alot of stuffing and tucking of the wires. Theres not much room back there (see pics).
After that just plug up your antenna adapter, plug both the harness and adapter into the radio, secure the 4 7 mms from earlier to the mounts on the sides, then snap the new bezle into place...
And thats it..test it out and enjoy your new radio.
