I will, like i said it should be here between the 24th and 30th and i should have it on in a week after that. Need a day off from both jobs to do it
Sent from my iPhone using Tapatalk
I wish you luck with your build as I will continue to watch it closely, but I have some personal concerns if that was my project.
1) I don't think that manifold will bolt to our 1.8 head
2) at a couple psi I don't think you will have to up injector size.
3) have you contacted trifecta yet?
After months of research and comparing im sure that it will bolt on. Also i have compared the exhaust mani gasket from a chevy aveo which has the same engine as the corsa vxr to the 1.8 in our sonics...they are identical.
