davecerv
Well for the 1.8L...4 quarts is not enough and checking your oil level immediately after driving/starting the car is not accurate at all. You have to give the oil time to get back down. That being said...I would add another half quart (if you only added 4)...give it a few minutes to settle on flat ground and check again (while the engine is cool and hasn't been running recently).
For future reference...4.8qts is the capacity for the 1.8.
I will check the oil right before I go back home after work. and yeah I know its 4.8 I'm just worried ill go over haha. Its not quite a quart left, its just a little under the line. The container should be almost empty for it to be 4.8 right?
