Blue hedgehog
Its not through gm its a lifetime unlimited mile through my dealer
Ok. Never heard of that.
fyi: I just picked up a 5qt jug of Mobil 1 5w-30 and noticed the bottle is labeled "Dexos2".
No luck finding the oil filter for the 1.4L at the local Wal Mart. Did find the Fram CH10246at Pep Boys, but it was $12!! Found the AC Delco PF2257G at amazon.com for $6.15 each, so ordered 4 of those.
Darin
Went to the dealer ship for an oil change today. I use Mobil 1 oil. I was going by the oil life monitor but living in North Dakota where the winter temps get pretty low and i warm up the car before i go someplace when the temps are below 0 my Oil life monitor was down to almost 10% after 5000 miles. Oil life monitor almost doubles that in the summer months here. I think the cold and warm ups has a big effect on how the OLM calculates the percentage. After they completed the oil change they told me since i use Mobil 1 i can ignore the oil life monitor and go 9000 miles between oil changes. I asked if this will go against the warranty and he said no. Do you think he is right or should i stick with what the OLM says?
Stinks?
I am refering to oil that may have fuel contamination; more common on the newer direct fuel injection equipped engines. The Equinox, in particular, had high pressure fuel pump seal problems and admitted raw fuel into the crankcase, causing dilution and contamination.
...After they completed the oil change they told me since i use Mobil 1 i can ignore the oil life monitor and go 9000 miles between oil changes. I asked if this will go against the warranty and he said no. Do you think he is right or should i stick with what the OLM says?
