Preloader
The M32 Martyr
I'm ready to grind down the tumblers in my intake manifold, and will gladly take step by step pics along the way. I would first like to see pics of one that has already been done.
YOU NEED AN ECP ENABLED TUNE FOR YOUR ENGINE TO RUN RIGHT WITH THIS MODIFICATION
Time: approx. 1.5 hrs
Tools:
8mm socket on 6" ext.(intake bolts x 6)
7mm (i/c charge pipe to throttle body)
10mm (nut for ground on fuel rail)
Torx 30 (fuel rail bolts x 2)
Die-grinder with 3/8" cylindrical bit preferred
Remove all intake manifold associated vacuum hoses and wire harness plugs. Tuck as much away towards the firewall, and towards the front of the engine.
Bleed off the fuel rail pressure, remove the fuel rail torx bolts and ground wire. Lift the rail up to gain access to the injector wire connectors and unplug them. There is no need to remove the injectors from the rail or to remove the fuel supply to the rail. Just lay the entire fuel injection rail assy off to the passenger side.
Now you can get to the 8mm bolts easily with a 6" extension. I prefer a 1/4" drive for almost any thing under this hood.
Once you get it unbolted, you can pull it up and access the vacuum line and connector on the bottom that need to be removed. It takes some fanagling to get the manifold freed from the engine bay, but it will come out.
Here is the 1/8" thick wall you want to remove.
I stuffed the runners full of paper towel to prevent the shavings from getting in the intake and gave it a go with the die-grinder.
Here is the result.
This project was surprisingly easy. In fact, all my projects on the Sonic have been relatively easy.
I will add some reviews on the performance effects of this mod once I get some decent road testing done.
Feel free to ask if you have any questions that I may not have answered.
Tools:
Here is the result.
