installed my ultra gauge in one of the vent openings concealing the wire. closed off the vent hole with a piece of foam camping pad. The gauge just leans in there and can be quickly pulled loose for accessing the back of the gauge.
This makes my head hurt.Here is what I'm doing to my virtual sonic. Building a light cover from a 3D scan. This was just a test of the software. I'll need to inset some scale cubes as reference objects to get an exact scaled photogrammetric model to build from and make actual 3D printed covers. I put blue tape over the reflective surfaces because that interferes with the accuracy of the model.
Removed aftermarket intake and went back to stock. It was causing problems so it had to go.
What brand was it? The cheap knock off ones don't have the correct tube diameter around the sensor. If it's one that uses an oiled filter, try cleaning your sensor with the maf cleaner.
Reverse modification - went back to stock wheels. Slowly going back to stock unless someone wants it with some goodies still on it!!
