Swordsmith
242hp/252 ft-lbs BNR EFI
Tired of my long sig, I'll keep editing this front post and add build details underneath
2012 Sonic Hatchback LT
1.4Turbo
6speed M32 Manual Transmission (OEM replaced by Chevy)
Victory Red
Cruise Control and Connectivity package
Checkered Duck Tape striping
Checkered Duck Tape bowties
Ultragauge or bluetooth ELM and Torque app
Exhaust replace: DDM high flow cat and catback with resonator delete from BNR
Shark fin antenna replace
DDM shifter bushings
OEM belly pan
lower mount from TTR
Forge BPV
New horn
LEDs behind slotted fog blank
Flexfuel setup: Buick Regal sensor, custom alcohol proof fuel line, BNR E85 injectors
RainX latitude wiper blades
Smoked lights (leaving reflectors unsmoked)
Plastidipped spoiler and "diffuser"
Chevy window deflectors (smoke)
RainX washer fluid
Vermont Tuner turbo revamp
RS steering
Bypass bypass
Repair rear end and replace bumper after accident
Personalized license plate
Raised bump stop for clutch 5/16ths of an inch
UHaul Trailer hitch
Chevy emblem brake light insert for trailer hitch
20mm hubcentric adaptors, rear wheels only (I like the wide rear end look, you other fella's can't deny)
MFab Intake with heat shield, removed stock saxophone
MFab Intercooler with hard charge tubes
BNR EFILive tune
1.4Turbo
Victory Red
OEM belly pan
Forge BPV
New horn
RainX washer fluid
RS steering
Bypass bypass
UHaul Trailer hitch
BNR EFILive tune
